If the engine overheats in a little over a mile, that indicates that you are NOT getting water circulation. This eliminates the fan clutch, transmission, dragging brakes, etc.
I would look at things that will stop the water from circulating like a bad thermostat or an air pocket in the cooling system that will cause the water pump to stop pumping. Check the thermostat with a pan of hot water to make sure that it opens completely and that it is installed correctly, and not backwards. Fill the system with water and properly bleed it to make sure that all air is removed.
