dougrainer wrote:
One thing that needs verified and IT NEEDS TO BE DONE FOR SAFETY REASONS. Access the 120 breaker panel in the RV and verify the tightness of the incoming 30 amp power wires(Black and White) to the breaker and breakers. After 25 years, they may have melted/burnt and now has a loose dangerous connection. Doug
Yea, I covered this already. I certainly wouldn't want to wait a few decades to do this. My latest rig was eight years old when I got it. The #6 wire feeding the DC bus was so loose the eyelet stake-on was barely touching the screw holding it to the bus, and the screw was two turns from falling off. This connection got so hot that it melted insulation on the wire. The #6 12 volt feed from the converter was also flopping around in the terminal, and got hot enough to melt the "tinning" off the bare end. I re-torqued everything I had access to, 120V and 12V.
