BusskipperExplorerDec 12, 2016Thermo Cube Thermostatically Controlled OutletAnyone Use This Cold Weather Thermo Cube Thermostatically Controlled Outlet - On at 35-Degrees/Off at 45-Degrees. I keep a couple of 150 watt Halogens in the Coach during the winter, use them to ke...Show More
eHoeflerExplorer IIDec 12, 2016I quit using them, have had several well houses freeze from them failing.
Related ContentSway Controldometic thermo probHow to fix Dometic Comfort Control thermostat problemsdura therm comfort control thermostatRemote Control Thermostat?
