BusskipperExplorerDec 12, 2016Thermo Cube Thermostatically Controlled OutletAnyone Use This Cold Weather Thermo Cube Thermostatically Controlled Outlet - On at 35-Degrees/Off at 45-Degrees. I keep a couple of 150 watt Halogens in the Coach during the winter, use them to ke...Show More
rgatijnet1Explorer IIIDec 12, 2016I've used this type for several years. Pretty much the same thing...on at 35 and off at 45.
Related ContentSway Controldometic thermo probHow to fix Dometic Comfort Control thermostat problemsdura therm comfort control thermostatRemote Control Thermostat?
