BusskipperExplorerDec 12, 2016Thermo Cube Thermostatically Controlled OutletAnyone Use This Cold Weather Thermo Cube Thermostatically Controlled Outlet - On at 35-Degrees/Off at 45-Degrees. I keep a couple of 150 watt Halogens in the Coach during the winter, use them to ke...Show More
Related ContentSway ControlHow to fix Dometic Comfort Control thermostat problemsdura therm comfort control thermostatdometic thermo probRemote Control Thermostat?
