BusskipperExplorerDec 12, 2016Thermo Cube Thermostatically Controlled OutletAnyone Use This Cold Weather Thermo Cube Thermostatically Controlled Outlet - On at 35-Degrees/Off at 45-Degrees. I keep a couple of 150 watt Halogens in the Coach during the winter, use them to ke...Show More
Peg_LegExplorerDec 12, 2016I use it in several places. Works for me with a 60 watt bulb and a clamp on light fixture with an alum reflector.
Related ContentSway Controldometic thermo probHow to fix Dometic Comfort Control thermostat problemsdura therm comfort control thermostatRemote Control Thermostat?
