BusskipperExplorerDec 12, 2016Thermo Cube Thermostatically Controlled OutletAnyone Use This Cold Weather Thermo Cube Thermostatically Controlled Outlet - On at 35-Degrees/Off at 45-Degrees. I keep a couple of 150 watt Halogens in the Coach during the winter, use them to ke...Show More
pianotunaNomad IIIDec 12, 2016Thermo cube seems to not be too reliable. I have one that works well and one that doesn't seem to work at all.
Related ContentSway Controldometic thermo probHow to fix Dometic Comfort Control thermostat problemsdura therm comfort control thermostatRemote Control Thermostat?
