bobndot
Jul 07, 2023Explorer III
The seal and valve are inexpensive.
The valve is plastic with tight tolerances.
There is a plastic plunger with an O ring inside the valve. Minerals from the water can build up or dirt from inside the freshwater tank can cause the plunger to malfunction at any time.
I mention dirt from the water tank bc i did a Netboy mod on my tank to clean the inside. I was very surprised to find so much build up inside the tank which i always kept sanitized over time.
Here is the interesting mod page that can be used on most RVs, not just TC’s.
I did the deck plate freshwater tank mod to gain access to my tank.
Hope you enjoy this mod page.
http://ourelkhorn.itgo.com/netboy/index.html
38,782 PostsLatest Activity: Sep 02, 2026
