thetundrawolf
Jul 15, 2013Explorer
Actually, I need to re- do everything. The shell, I mean. My stepdad said not to buy 2x2's, as we can get 2 of them from a 2x4 for half the cost XD I plan on using polystyrene sheets as insulation, and expanding foam to seal the cracks. A gallon or two of elastomeric sealer and a few tubes of silicone caulking. It really is falling apart on the inside as it was stored by the ocean. And it's thirty years old. Being a carpenter, he said to build cabinets all over the inside (I like it more open- a bathroom only because it is mandatory) to reinforce everything, but I am not entirely sure if that is necessary.
So, the plan is to strip the tin off (Is there a product I can use to repair the holes and tears in it? It's not in that great of condition. Something like a solder?) and duplicate the 2x2's, plus maybe an inch so I can actually stand up in it.
I want to build some storage units on the underside of the RV, and maybe have them accessible from the inside, as well as outside.
Electrical will be run alone the inside of the walls, where I can get to it, and upgrade/add/repair it as needed, in a tasteful fashion, of course. Plumbing will be PEX and run underneath the RV.
I am on an extreme budget, but I need to do this. With the polystyrene sheeting, expanding foam, elastomeric sealer, and ripped 2x4's, I am hoping to get it done for less than $500. I already have the plywood. I would have liked to have gotten the marine grade plywood, but I cannot afford it. i will seal this plywood up good, though.
38,777 PostsLatest Activity: May 24, 2026
