edatlanta
Aug 07, 2016Explorer II
I just replaced my second Thin-Lite fluorescent fixture after both had ballast failures. The replacement I used was a Thin-Lite DIST-LED616P. It is LED, 6" longer than the original with the F8T5 fluorescent bulbs. The extra length lights more of my counter top area and is much better and the fixture is the same width as the original so fit wasn't a problem. The LED fixture contains a one button dimmer that remembers your last dimmed position and is great for a night light. I use a setting of about mid-brightness most of the time since full brightness is "darn bright".
Thin-Lite doesn't make their LED products easy to find for some reason, but I ordered mine from a company in MN and it arrived promptly and on time.
38,782 PostsLatest Activity: Sep 10, 2026
