miller2540's avatar
miller2540
Thinking about downsizing from Class A to a Class C
We are thinking about downsizing from a Class A to a Class C. We love the floor plan of both of the Minnie Winnie 31K and the Coachmen Leprechaun 319DSF but there are certain things about each that we do not like. If we go with Winnebago we would miss the closet space of our present coach that is found in the Coachmen and if we go with the Coachmen, the membrane roof is a concern. The swivel front seats and outdoor TV are plusses for the Coachmen but so is the fiberglass roof on the Minnie Winnie. There are also posts elsewhere about leaking front caps in the Coachmen. Do any of you out there have ideas on how to overcome smaller closets of the Winnebago or the membrane roof of the Coachmen?
  • Unless you are married to the Winnie and Coachmen Class C...and since they aparently don't have have you want...look at some of the other brands.
    Membrane roofs should not be a negative factor in considering a new RV. So you shouldn't automatically disqualify a Class C brand because of the membrane roofs. And Fiberglass roofs like Winnebago uses aren't maintenance free either.
    Winnabago uses a thin sheet of filon fiberglass bonded to foam just like most RV's walls. You still have to recaulk them just like membrane roofs, and tree branches can also punch holes in it just like Membrane Covered roofs.
    The newest RV Roofing membrane materials are rugged, long lasting and almost completely maintenance free (aside from routine recaulking the edges and roof vents).
    Jayco and Forest River uses the new Alpha Systems vinyl roofing material. Unlike older roofing systems, it doesn't break down like the tpo/rubber roof membrane did, it has a golf-ball like stippling like texture to it.
    Look at the Forest River Forester Class C's, the Forest River Lexingtons (Forest River is owned by Billionaire Warren Buffet his trendous buying power means better quality and actual quality name brand stuff used in making one!).
    Jayco Greyhawks and Redhawk (they all have 100% high pressure laminated construction) 10 times less likely to delaminate than the walls that the Winnebago's has.
    Jayco's also have a 2 year bumper to bumper warranty, in business (same family) since 1967 and Jayco has double the edge seals as other brands which also helps keep leaks away.
    Spend time researching online AND looking at dealership and RV Shows.
    Lazy Daze is excellant quality and basically hand made to your order here in Southern California by a 57 Year old company...roomy and open floorplans, and considering this level of good stuff are still priced reasonably...but NOT available with slideouts.
    Good luck!
  • How big of A do you have? Going to a 31-32' C isn't what I would call downsizing. JMHO I would stick with a A your happy with. Dick
  • GENECOP wrote:
    Check out Nexus, or Triple E, lastly Lazy Daze....these three are better quality than Winn or Coach..
    X2
    I admit to being biased but when you get lucky enough to find a nice Nexus...
    I would not buy any coach that didn't have a one piece fiberglass roof, solid one piece end caps and all of the other quality features that our Nexus came with.:C
  • Check out Nexus, or Triple E, lastly Lazy Daze....these three are better quality than Winn or Coach..
