msmith1199
Apr 28, 2014Explorer II
Foodsman wrote:
Regarding "because I don't want to have the road restriction issue" do you mean side roads or are there road restrictions on a state by state basis I'm not aware of?
As for the "50amp power supply" wow, I sure never thought of that... Not being able to hook to power with friends and family never accured to me. Any alternative?
Thank you
California has road's that are restricted to vehicles over 45 feet. Highway 1 along the coast, many of the two-lane mountain passes, and roads such as that.
The alternative on the power is to run your generator, but when you're outside of somebodies house that may get annoying, and expensive on the fuel. I don't know if it's difficult, or even possible, to tap into somebodies electrical panel and install a temporary 50 amp receptacle or not. If you are staying with the same set of friends and relatives you may just be able to go ahead and install a 50 amp receptacle at their house so it's there for your use.
You also need to figure out a way to dump your holding tanks if you're at somebodies house. Many houses have sewer cleanouts installed outside and you can dump into one of those.
