OhhWell
Apr 29, 2014Explorer
Foodsman wrote:
One question I have is you see 40 ft DP with 8 rear wheels and others of the same or close to the same size with 4 rear wheels. What is the decision making process to decide on one from the other? I am clueless on this issue and would appreciate your help with it.
The second axle only has 2 tires on it and is referred to as a Tag Axle. If you do a scan through the posts here or a search you will find all the information you would need to know about them repeated over and over. That question seems to come up at least once a week.
As for plugging in at freinds' houses: You can run a main A/C on 20amp and a couple little things like an LED TV at the same time but that's about it. There is a very smart but not cheap power converter/inverter that will boost your coach 110v with the inverter while plugged into 20amp service using the house batteries to cover high demands. I wish I could remember who makes it but it would be something to consider.
