2gypsies1
May 02, 2014Explorer III
Some to look at for starters: Newmar (prejudiced); Country Coach; Beaver
Many mfg. use the same components, i.e. furnaces, air conditioners, toilets, etc. The inside carpentry can give you a hint of quality. Look at the fit of the doors, trim, cabinets, drawers. If you're full-timing you want something that can withstand constant daily use. Carpeting you can always change out or replace with a solid floor. You can easily change furniture and window coverings, if needed, so if looking at used overlook the cosmetic issues and zero in on the build.
