mlts22's avatar
mlts22
Explorer II
May 18, 2016
Thor Gemini reviews?
I'm curious... does anyone have a Ford Transit based Thor Gemini? It looks like the same floor plan as the Fuse, except with the bed slide either directly behind or going to the driver's side. The price is not too bad either. However, there are some things which cause me to scratch my head. The rear bed slide model has two gray tanks (technically 31 gallon FW, 19.5 and 18 gallon gray, and 28.5 black), and I can't find any info if the tanks are connected, or if they have separate drain ports (which pretty much doubles the time spent dumping.) The driver's bed slide model has a 31 gallon FW tank, 37 gallon gray tank and a relatively tiny 19.5 gallon black tank.
Inside, the Gemini seems to have some nice features, like being able to lift up the bottom of the bed and use it as a secondary bench with a table. However, I have not seen many reviews on it. The Winnebago Fuse is more expensive, but I have met very polite people who were more than helpful when answering my relatively banal questions about the rig.
No RepliesBe the first to reply
