jolooote's avatar
jolooote
Thor Vegas 12V Cigar plugs?
We have a 2015 Thor Vegas 24.1 Class 'A' Motorhome. The two 12volt cigar plug ports at the center console have no power. Anyone know which fuse or 12 volt connect point and where its located? :?
  • We finally found it. Its a yellow 20 amp fuse in the big black electric box in the front outside compartment under the driver.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    If Thor is doing what Damon (A Thor company) did then the jacks on the dash are Chassis devices, I have a Workhorse it has 3 fuse panels for the chassis (one is part house) and frankly I'm not sure which one powers the dash.
    OTHER 12 volt outlets are HOUSE devices (The one by the passenger foot and the ones I put in) Those I know where the fuses are (Since I put 'em in)
    Dash units may or may not need key on (Some do some do not, GM does not and someone said FORD does not DODGE.. Does)
  • Vegas is on a E-350 chassis.
    I'm not sure what Thor provides in the motorhome, but Ford provides two 15-amp 12 volt power points (not cigar lighters, those are a different specification) for the front dash, from the power distribution box. These are always live in the E-350 van.
    Thor could be doing something quite different, but most likely they will be providing 12-volt power points, rather than lighter sockets.
  • Do you have the key on?
    Most of these are now set to only be on with the ignition .
