Dale_Traveling
Aug 21, 2015Explorer II
Check the position of the drive arm at the wiper motor and at the based of the wiper for possible adjustment. The position of the arms with respect to the center pivot point establishes the total swing of the wiper. Closer to the center is less swing.
I suspect the with the OP's coach the offending side either wasn't set correctly during installation or has slipped. Once the swing angle is reestablished you might need to pull the arm as Bill described to reestablish the off or stow position.
If one side is off but the other is good duplicate the position of the good side by measuring the distance from the centers of the pivot and the drive arm. The trick is the amount of room to access the wiper motor and the base of the wiper arms.
38,777 PostsLatest Activity: May 24, 2026
