Bruce_Brown
Nov 02, 2016Moderator
RVER wrote:
I tried out some Ford V-10 s in newer units but HATED the noise, friends told me, "you will get used to it" NOT!! I did like the smooth quiet engine of the this GM. WE do want to go to Montana and Yellowstone etc so hope it works out. The rig is beautifully taken care of with real wood inside, carpeting is clean etc.
The V10 certainly does rev, but normally the noise you'll be hearing is as much of a function of the builder than the engine. It's pretty easy to insulate against the noise - some just do a better job than others.
