bobbyg123 wrote:
gemsworld wrote:
Some are put together better than others, and in some cases, better materials such as a fiberglass roof. Out of the brands you mentioned, I'd go with Winnebago.
Thanks. I should have been more clear on what I was asking for. Things like roof quality or other "extra" build quality touches that some manufacturers use over others.
As a general rule, given all else equal, a smaller rig would naturally be stronger than a bigger rig.....just like various sizes of cardboard boxes made of the same corrugated material. Also, a strong multi-layered rear wall will help to keep the box square.
Phoenix Cruisers are lower in height, narrower in width, have a very strong multi-layered rear wall system, walls-sit-on-floor construction, and aluminum framed openings, all combined keeps the integrity of the house together better than many other brands. The crowned roof with a single sheet of fiberglass rolled over the side edges, overlapping the side walls, along with the seamless frontal cap, increases protection against water penetration. Our 11 year old PC-2350
SEEN HERE is extremely well built. Owning it since new, I am still very pleased with it's durability, design, and workmanship. It's still a tight rig.....good quality as evident 11 years and 38,000 miles later.
Phoenix Cruisers are not common in the northwest, but they are there. The Phoenix Cruiser forum
HERE has some members in Washington state.
