bobbyg123's avatar
bobbyg123
Thoughts on manufacturers
Since I'm in the market for a used Class C, out of necessity, I'm open to a variety of different manufacturers. Without wanting this to turn into a brand loyalty debate, what can you guys tell me about the different Class C makers?
I'm in the market for a 25-31' camper, and the makes I'm consistently running into here in the Pacific NW are Thor, Sunseeker, Minnie Winnie, Tioga, and Jayco.
Any input on these would be helpful.
  • It helps to have a bit better idea what you might want in a Class C. But we are pretty pleased with the build in our Winnebago. Even Winnebago has levels of build with their C's. A one piece nose cap is a necessity, fiberglass roof too. Cubic feet of storage space is important to some. Large shower to others. Rotating front seats can be nice too. One feature that might be more common now in other rigs is the hot water tank has a heating element that carries engine heat through the tank. Rather nice to drive, then have a tank of hot water when you arrive. Winnebago also has a different key than the commom one too. Also electrically heated grey and black tanks if needed. Better mattresses, fit and finish. Even a water filter in the top models.
  • gemsworld wrote:
    Some are put together better than others, and in some cases, better materials such as a fiberglass roof. Out of the brands you mentioned, I'd go with Winnebago.
    Thanks. I should have been more clear on what I was asking for. Things like roof quality or other "extra" build quality touches that some manufacturers use over others.
  • Anonymous's avatar
    Anonymous
    Not applicable
