Assyrian_Elvis
Oct 17, 2014Explorer II
Assyrian_Elvis wrote:Arizona Kid wrote:
Horizontal tanks do not need re-certified, but a system that old should be throughly checked out by someone. (expert) You may still run into problems with places refusing to fill your tank, because it doesn't have an OPD valve, even though it's legal.
Also, and this goes for everyone, check all the screws holding the ground wires on the bus bar, and check the wires going to the breakers. These tend to vibrate loose, and can short frying a breaker, or cause a fire. These should be checked at least once a year.
AZKID, should I take my unit to camping world or some other rv place. Businesses that sell propane only fill your tank they do not certify or inspect the propane system. BTW we turned on the furnace and it works but it wasnt blowing hot air, do you know why? There is propane in the tank.
MR KK, I agree with you also im kinda confused what hes talking about. What about yourself kk, what do you do every year to check or inspect your propane system. Im new to the rv lifestyle and im not a mechanic.
