Assyrian_Elvis
Oct 18, 2014Explorer II
Arizona Kid wrote:KK&R wrote:
Az Kid,
Could you clarify in less technical terms what you refer to as " all the screws holding the ground wires on the bus bar." I'd like to do this, but bus bar is not a term with which I am familiar.
Also, by "wires going to the breakers," do you mean the wires that end up in the breaker/fuse box behind the sheet metal housing the converter? So you mean just tighten their connections with a screwdriver? Clarification appreciated.
Yes by the converter. The ground wires are attached to a bar, called a bus bar, or ground bar. There are set screws for several black ground wires.
Disconnect the battery first.
Bus bar is the verticle white piece with the set screws. Others may vary. All wires should be checked, and tightened if needed.
So where is this on my van? Im new to this. Just wondering.
