LoadUpLetsGo's avatar
LoadUpLetsGo
Tiffin Phaeton Owners
Hello all, Looking to tap into the wealth of experience and knowledge here. I tried searching and couldn't come up with what I am looking for, so if this has been discussed before please forgive me. I'm looking at buying a 2008 Tiffin Phaeton 42' coach and would like to hear from you the good and bad of this model. Is there anything in particular that I should look for when I go to look at it? Any options that would ad to the cost? Any known problems with this model year? Thank you in advance for your help. If you need any more specifics, let me know.
Eric.
  • As stated previously check out the Tiffin RV Network.
    I recently purchased a 2007 Allegro Bus and was able to get valuable information from the forum prior to purchase.
    Make sure you read up on the what the call the Big 3 Issues which I think the 2008 Phaeton could have. (Wetbay, Roof Rails and Driver Side Slide)
    My 2007 had the wet bay issue which I was able to get repaired at no cost to me even though the coach is seven years old. Tiffin is fixing these issues for up to eight years after build date. I made arrangements for repair prior to purchase (locally) to make sure I was covered. When I did my research the driver slide issue requires a trip back to Red Bay the others can be fixed by approved repair shops other than Red Bay.
  • You should post your question on tiffinrvnetwork.com
    Its a forum for Tiffin owners and others and is a wealth of information.
    You will get many responses.
