rgatijnet1
Jan 04, 2017Explorer III
I know you had some severe rusting problems with your chassis and I think I mentioned before about the possibility of high water damage.
I am not sure of your capabilities but I would have someone go underneath your coach and inspect ALL of the wiring. While under there, I would disconnect each electrical connection, coat it liberally with Dielectric grease(Click here) and then see if that helps with your problems. Corroded electrical connections can cause problems that come and go and are extremely difficult to diagnose. The Dielectric grease will prevent further deterioration and may eliminate some of the things that you have experienced. Doing nothing and letting your coach sit in the high Florida humidity is going to aggravate any corrosion that you already have.
38,780 PostsLatest Activity: Nov 24, 2017
