the_bear_II
May 19, 2017Explorer
I don't know if you have an automatic awning or a manual. Foe my manual awning I deploy the awning completely and lock it down. Then I disconnect the awning down tubes from the latches at bottom of my RV (Note: These Down tubes carry a lot of weight so be ready for it). I slide the down tubes under my RV. This flattens the awning on to the side of the RV and makes it easy to clean the top side of the awning....
I only use water and a soft long handle brush attached to my hose to clean off the dirt. For any spots I use simple green spray and srub with the brush. Rinse and dry then raise the down rubes back up in to the latches.
Then clean the bottom side of the awning.
