magnusfide
Oct 03, 2014Explorer II
nomad 289 wrote:Old-Biscuit wrote:
Just make the turn as normal..just like you would do in car/truck
If the turn is made "normally", the tail will swing into the adjacent lane of traffic, either hitting the side of a passing car or getting rear-ended since most drivers do not anticipate the lane encroachment.
Old Biscuit is right; make the turn as normal. My C is longer than yours and we don't have that problem.
If you slow enough, use your signal, then you should be fine. The other drivers are required by law to keep an eye out for your maneuvers too.
38,769 PostsLatest Activity: Apr 03, 2026
