Hank85713
Jun 25, 2014Explorer
I also have an aspect and the biggest thing with it is its a tail dragger! Any small bump will cause bars and the hose hanger I installed to hit. Even going over rutted drives are a problem. I use any station where there is maneuver room. I will wait to get an end pump but if I have to I will drive to the opposite side. Pilot and others generally have the pumps perpendicular to the roadways and can sometime be a problem, but again be patient and wait to use end pumps. Went to a TA yesterday and it was set up for cars so just pulled thru truck lot and left. When making turns, pull forward some before initiating your turns make the coach a square turn at first and adjust as needed. Towd will follow. Now if its a 31 or longer tail swing will get ya, got to account for that extra 3-4 feet back there. As above fuel when arounf 1/2 tank, gives ya more options. used a Safeway yesterday nice pull thrus from all directions. Look out at auto specific places like circle k's or the minimart types. Costcos and some walmarts have big station lots but small entrances.
38,778 PostsLatest Activity: Jun 06, 2026
