cbr46 wrote:
I bought Dyna Beads for a wheel imbalance but they sit in a bag on the counter . . . . .
I think I can break the bead on the tires and slip them in through a tube without getting them caught in the tire bead. I shouldn't even need to dismount the wheel. My fear is re-inflating the tire on the chassis without a cage. Thoughts?
Best,
- bob
It is a little bit of a pain but if you have a small hose and a funnel, you can install them right through your valve stem once you remove the valve core. No need to break the bead.
