rgatijnet1 wrote:
cbr46 wrote:
I bought Dyna Beads for a wheel imbalance but they sit in a bag on the counter . . . . .
I think I can break the bead on the tires and slip them in through a tube without getting them caught in the tire bead. I shouldn't even need to dismount the wheel. My fear is re-inflating the tire on the chassis without a cage. Thoughts?
Best,
- bob
It is a little bit of a pain but if you have a small hose and a funnel, you can install them right through your valve stem once you remove the valve core. No need to break the bead.
The RV Dyna Beads are too large for the valve stem by design. As a result the special filtered valve cores aren't required.
My concern is re-seating a "truck" tire with my head right next to the bead. At least if it's on the RV it won't move. Still . . . . can bad things happen?
Best,
- bob
