loggenrock
Jan 16, 2014Explorer
Hi - go to http://www.tirechain.com/TRUCK-SUV-CHAINS.HTM . I have a set of the diamond quickfit that I put on my 03C190P. I haven't needed to use them much - only a couple times - but I haven't had a clearance issue. You can get a Type S - which is a reduced clearance chain - to fit the 265/75-R16 which is my tire size - I can't recall if I went with the reduced clearance or not... As far as speed - the recommendation is not over 35 mph. However, if it is bad enough to warrant tire chains you likely won't be doing more than 20-25mph! I use this style of tire chain on my AWD Subaru's, too. Applys in about 8 minutes, removal sometimes a bit longer. Expect to get dirty - you are in a wheel well covered with road slime... Just had to chain up this past weekend just to get home from work (and back again the next day...dedicated or stupid...???). I carry mine year-round in the RT - have used them in muddy conditions for better traction, too. Not off-roading, but just coming up a wet grade out of a campsite... ST
38,782 PostsLatest Activity: Sep 10, 2026
