pigman1
May 16, 2019Explorer
BillyBob Jim wrote:Sorry, I don't agree at all. First off for the OP. You told the dealer what you wanted and he apparently agreed to furnish them as you wanted. Now he wants you to take something you specifically told him you didn't want? Not a chance if it were me.magicbus wrote:
So you are willing to accept 6 or 7 months but 12 is too much? IMHO you are overthinking the problem. These tires spent those unacceptable 5 months stored inside, not exposed to sun, moisture, asphalt or road debris, and without 5-10 tons sitting on them while under-inflated and often parked in the same spot. I would put them on the coach and save the receipt so I knew when it was time to think about replacing them again.
Dave
Finally folks, Common sense rears it's ugly head LOL.
As far as the business about tires that were stored inside, not run, and not loaded. A VERY rash statement that is entirely unprovable. I just replaced 4 drive axle tires that were original to the 2013 Bus. These tires had over 101,000 miles on them and the sidewalls were uncracked and unchecked. I wore the tread off them, and if I had been able to find someone to regroove them I would have gone that way for about another 50,000 or more miles. My tire guys said mine were the first worn out RV tires they'd ever seen. Saw a lot of cracked and rotted sidewall ones, however. Tires that are USED and not allowed to sit keep the oils inside the rubber moving around and do not rot. For almost all RV'ers, this is not the case, so the tire rots, and the rot starts the minute the tire is built. Every hour that tire is not being run is costing you money as it'll have to be replaced sooner and you're not using it to go where you want to go.
Push on the tire dealer a final time, and if he is still being stupid, go elsewhere. You do need to give a dealer a few weeks to get fresh tires in, and if he can't, he's not someone I'd EVER want to deal with. It's his business to get you what you both agreed to. If he can't some accommodation needs to be made or you need to walk.
