Yesterday on the way home, I stopped at the scales. In round numbers, the front weighed 3,800 lbs. and the rear (dual) was 6,900 lbs. I was able to get both axles on the scale, so the front and rear d...
If you call Your tire manufacturer with the weight of the vehicle (4corner weight), the Customer Service person will give you the recommended PSI for every tire.
