fla-gypsy
Apr 29, 2015Explorer
wolfe10 wrote:dan-nickie wrote:rfsod48 wrote:
By rv recommended pressure I mean what is posted by manufacture of mh on weight sticker listing GAWR.
No, I don't think you should add air over the 'sticker' as that is typically stated as the pressure at 'maximum' loaded coach.
That will get you a rough and squirrelly ride.
Totally agree. The PSI on the GVWR sticker is for each axle LOADED TO ITS Gross Axle Carrying Capacity!
Any new person reading this thread is totally confused by now but this is the correct "safe" pressure to run. It is possible to use individual weights for each tire position but is totally not necessary if you fill to maximum specified by the vehicle makers cold PSI rating and you can be assured you have acheived the maximum weight carrying capacity for those tires.
