wolfe10
Apr 29, 2015Explorer
rfsod48 wrote:
I have seen it posted many times to inflate tires 5-10# over rv listed tire pressure. Why would you do this?
It is confusing, because this original post did not specify what "rv listed tire pressure" he was referring to.
Most assumed he was talking about the tire manufacturer's inflation tables which specifies PSI based on actual weight.
Very different than the GVWR sticker pressures which are for each axle loaded to its Gross Axle Weight Rating.
Factoring that in clarifies a lot of the "variance".
