Tom_Barb
Apr 29, 2015Explorer II
Ivylog wrote:
I go 5 over my weighed pressures because I'll still travel in a good cross wind. It will shift enough weight to the downwind side to overload those tires if at the minimum pressure.
When using a TPMS you can find the proper pressure you should be running, when you get out in the wind, you can watch the tires that are flexing more raise the pressure and temp. The windward side will actually decrease in temp. and the pressure will drop.
