We bought a used Jayco Grayhawk 31ft. Class C E450 frame. The tires were all inflated to 80psi. The door sticker says Rears 80psi cold and the fronts 65psi cold. Wondering what tire pressure all of yo...
CapriRacer I must take exception to the info contained in the above reply: Everything your note warns about is covered in the recommended pressure figure given for the load/PSI in the Michelin charts. (crowned highways, side-to-side differences, etc., etc., etc) If you start putting out personal recommendations you are just negating the good information provided by these charts.
5% 'RESERVE', OK if it makes you feel better.
'40 YEARS IN THE RADIAL TIRE INDUSTRY, SEEN IT ALL AND DONE MOST OF IT'
