wolfe10
Aug 09, 2014Explorer
Please post your GAWR's for each axle. More weight on tag also puts more weight on front axle and removes it from the drive axle. Until you know how the front axle is loaded (percent of GAWR)it is not reasonable to make adjustments.
Ideally, you want the same percent of GAWR on each axle.
As far as left/right imbalance I would check ride height. Actually, anytime you are fine tuning weights/tire pressures, it is a good idea to check ride heights. If one of the two ride height valves on the drive axle is mis-adjusted, it can give you a lot of left/right imbalance-- think of how many of your really strong friends it would take to raise one side of the rear of your coach even 1"!
38,769 PostsLatest Activity: Mar 28, 2026
