way2roll
Mar 07, 2021Trailblazer
Ed C wrote:
You need to know the weight...at each corner or at least each axle. Then you can check the tire manufacture's chart for those weights. If the tire pressures are right the temperature doesn't matter unless it changes drastically
I would add that it needs weighed while loaded for travel.
38,780 PostsLatest Activity: Aug 05, 2026
