Executive45
Mar 07, 2021Explorer III
Any Pilot/Flying J will have a scale. DON'T BE INTIMIDATED! THEY ARE THERE AND WILL HELP YOU! Pull onto the scale, placing each axle on each scale. Put it in neutral and release the parking brake. There is a microphone to talk to the cashier. Tell them you're an RV and want a weight ticket. They will tell you when they are through. Takes about 30 seconds. Pull off the scale and go inside for your weight ticket. Adjust your tire pressure as per mfg recommendations.....four corner weighing is best but it's more expensive and harder to find someone who will do it. Axle weighing is next best and will give you enough info to properly air your tires. Altitude and temperature will also affect PSI in your tires so adjust for that if traveling. I set my PSI twice a year (summer and winter) and rely on my TPMS while traveling.....Dennis
38,782 PostsLatest Activity: Sep 10, 2026
