wolfe10
Mar 07, 2021Explorer
JRscooby wrote:
Remember if you have been driving, pull in to weigh your snot, and adjust the pressure, next morning, when your tires are the same temp as outside air, you are setting on underinflated tires. Within a hour you might be setting alongside the road
Correct!
Proper order is:
Get weight ticket
From your tire manufacturer's Inflation Table, determine proper minimum PSI based on axle weights. Add 10-15% as a safety cushion-- perhaps 15-20%, as you need to account for left/right imbalance.
ONLY adjust PSI before driving more than a mile or two and better in the morning (after sitting overnight) as ambient temperatures are lower and you need to be able to have correct PSI when you start out in the morning.
38,782 PostsLatest Activity: Sep 10, 2026
