rgatijnet1
Aug 05, 2016Explorer III
If the tires were set to the correct pressure, based upon having the coach weighed when fully loaded, then the rise in pressure or temperature is normal, no matter what it is.
The big variable is that if you have NOT had the coach weighed, and the tires set to the proper temperature, then you have no way of knowing what is a normal increase in temperature. If the tire pressure is too low, the temperature will go up quickly.
38,782 PostsLatest Activity: Sep 10, 2026
