rgatijnet1
Nov 14, 2018Explorer III
I preferred the Crossfire tire gauges for my duals. You purchase these for the specific PSI that you want and then they tie both of your duals together and balance out the pressure in both. Then all it takes is a glance at the gauge to see if the pressure is OK. If one tire does get a puncture, it will not allow both to deflate. It also means you only have one valve to inflate both tires at the same time with the exact same tire pressure.
38,782 PostsLatest Activity: Sep 10, 2026
