mikemc53's avatar
mikemc53
Explorer II
Apr 13, 2023
Tire Pressure?
2022 Gulfstream Conquest 6280 on a Ford E350 chassis. The tire pressure recommended on the driver door tag says 75 psi front and 65 psi rear (drw). Last year I had a young tire tech tell me that they should all be at 80 psi, which I thought might be a bit high.
I run about 80-85% weight capacity and I was wondering if the door tag is accurate. The reason I ask is that the door tags are likely put on before the vehicle is modified to become a motorhome. Would that change the recommended tire pressure?
Thanks in advance.
No RepliesBe the first to reply
