j-d
Sep 23, 2014Explorer II
You can use Michelin's RV Tire Pressure Chart
Just note:
1. Pick your EXACT tire designation to match the Chart
2. Be sure to use the Single info for the Front and Dual for the Rear
3. The Michelin chart is by Corner, so double their number when working with your weights by Axle
Your chassis is probably E350, maybe came with Load Range "D" tires, and the door label reflects pressure for maximum axle capacity (GAWR). You need less than that for the scale weights you reported.
Just note:
38,771 PostsLatest Activity: Apr 22, 2026
