j-d
Sep 24, 2014Explorer II
Handling? Well, it's a little tail-heavy. You have 30% of loaded weight on the front axle and Ford want 33% minimum. Some say load the front to 75% or more and you have 82%. Still:
Move any weight that you can, forward. Or simply carry less in the rear, behind the axle.
Make sure Front End Alignment is Correct. If it isn't, have CASTER set to at least 5-degrees.
Adjust Tire Pressures...
Next step I think I'd add a heavy duty 1-1/2" diameter rear sway bar. Hellwig is less expensive than Roadmaster and has the same specs.
As a group, the short Class C's AND the long ones seem to have less handling issues than the in-between ones.
38,771 PostsLatest Activity: Apr 22, 2026
