Mich_F
Sep 25, 2014Explorer
jillhop sorry that I couldn't get the tank capacities for you today. Should be able to get them tomorrow. I think if you dropped your front tire psi to 60# that would give you plenty of cushion over the weight you are carrying on the front axle and be at 75% of the max 80# psi of your tires, assuming you have load range E tires, and it should improve your ride.
I just found this online for the 1997. Not sure if everything is accurate. I know my son told me the water tank is listed on mine as 43 gal, but on the specs. here it's 37 gal ?
1997 Coachmen Specs
1997 Coachmen Specs
38,776 PostsLatest Activity: May 15, 2026
