goufgatorsExplorerFeb 28, 2015Tire psiAs most (if not all) of you know, psi increases as tires warm up due to driving. My experience, here in Fl. where air and road temperatures get ungodly hot, is that it is not unusual for tires to gain...Show More
CapriRacerExplorer IIFeb 28, 2015Well, for one, the load carrying capacity of a tire is based on the COLD inflation pressure - and that means the pressure buildup is expected.So if you start at 85 psi cold, then the load carrying capacity is based on 85 psi, not the 90 psi when the pressure builds up.
