rgatijnet1 wrote:
He's a senior member with over 400 posts so I would guess that he just transposed the numbers which were actually 1715. Easy enough to do especially if you are dyslectic.
Well I didn't expect to get some of these responses. Yes it was a long day, and I transposed the date codes. I will get down on my knees and beg for forgiveness. I have been on this board long enough that I wasn't expecting to be accused of posting a bullsh't post. I have way better things to do. I think before you jump down someone's throat you should think before you post something inciting a word fight.
In any event, in answer to why I replaced the tires, they were worn out as in down to the wear bars, not replaced due to sidewall cracking or such. They had 90,000 miles on them, and I wasn't about to push my luck.
Finally, I decided to keep the older date tires. The deal was too good to pass up. More than likely, they will get worn out before they age out, although I have been putting less mileage on the coach as of late.
