This is my first time replacing tires on a DP and I am a bit confused. I have Goodyear 295/80R22.5 on my DP. They are original with 05 date code. They still look good, no sidewall cracking, well over ...
Tires should be sized and rated to a minimum of your axle rating. Anything less will cause your axle rating to be derated to the tires specs. I think Hankook is an excellent tire and are highly rated, but get tires that have a rating at least 7200 pounds each on the front.
