jjson775's avatar
jjson775
Tire rotation with duals
Do most owners of RV's with dual rear wheels get their tires rotated regularly? If so, what is the rotation pattern? I will appreciate any feedback.
  • I don't rotate the tires by position, as most others, since their lifespan is not limited by treadwear in any way.
    I do rotate the tires around their axis every single time I move the motorhome; failing to do so leads to very rapid and uneven treadwear (and very bad gas milage). :B
    I just got back from the tire store an hour or so ago to price out a set of tires, as chance would have it. I probably would have waited another year, but had an unfortunate incident with a curb that put a nice deep divot in a sidewall...so rather than have a single mismatched tire to contend with (and trying to figure out how to distribute the others sensibly), I figured it was time. The tread still looks practically new.
  • No, I don't rotate them regularly or at all. They're wearing nice and evenly back there.
    Bill
  • I rotate the front tires with the spare to give the spare some use. The rear duals stay where they are until new tires are needed.
  • Most people don't rotate, nor even have them rebalanced.
    However, not being most people, I rotate when I have 'em rebalanced at around and interval of 10Kmiles. As the '99 ford chassis has identical wheels on all 6 positions, I rotate thus:
    Left front to left outside dual
    Left outside dual to left inside dual
    Left inside dual to left front
    Likewise for the right side.
  • I have rotated side to side but decided it was not worth it so I have quit doing this.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Considering that the tires will age out long before they wear out, I don't rotate my tires.
  • The two duallies I have owned seemed to wear the rear tires pretty flat and evenly, so I saw no reason to rotate them. The front tires I would rotate side-to-side if I thought they needed it.
  • Only move them side-to-side so that they run in reverse rotation.
    Given the nature of the rims, a full rotation would require taking the tires off the rims.
    And that's just asking for trouble X6 - especially when some mechanic is doing it for you.
    I ran 80,000 miles on the first set of tires doing it that way. Not planning to change now.
